New exhaust....done....:D - V6 noise porn inhere!
Yes, but mine are all in one pretty line, and they power the correct wheels. You're missing two cylinders for a V setup, and the wrong wheels are powered. :p
Your engine is in the wrong shape and driven by a fag, i.e...you :p
Sounds good, and looks quite good too mate, only thing, isn't the tip a little sharp...would you likely catch trousers on it or even legs?
No, the bumper sort of comes out to compensate for the exhaust tip so the chances of your leg catching on it is minimal :)
i suppose you've got to have something to console yourself with when you get overtaken by a rover ;)
I've been overtaken by lots of things...I drive quite saintly. :p
As in rip trousers or cut legs if you bump into it.
Fair enough, looks like it sticks out...but also looks like it doesn't...crazy photography skills you have. :p
to be fair, the tip on mine is rounded
that one isnt. I think thats what hes getting at. but you'd have to be a **** to injur yourself with it :p
It's slash cut, that's how they are:confused: Mine is the same, but I don't walk into my car often:p
Give it a few days
"Just slit my shin on my ****in exhaust!!!" :p
I could've had an inward rolled xpower backbox but it was A) more expensive and B) very boomy/chavvy - no thanks! :)
Woah, sounds a lot better than i was expecting, but for some reason i don't really like the tip - it looks like the ones chavs have on their 1.0 Corsa's. I like exhausts with a rolled end - makes it look classier :D
I have rolled ends on mine but it's a PITA to dry the exhaust after a proper wash... so water just sits in the exhaust tip until you next take it out for a good blat. Apart from that yeah I think rolled ends look slightly better as it makes the exhaust look more professionally made.
My factory exhaust:
Wouldn't really call it chavvy.
