World's fastest roller coaster opening June 2009 Germany
No idea but a top fuel dragster can hit 100mph in under a second. They are pushing 280+mph in 2.5 seconds ;)
This ride looks awesome :cool:
I went on stealth when they had it rigged for 0-82MPH in 1.8 seconds (normally 2.5 I think) and that was pretty rough - 0-130+ in 2.5 would be a bit extreme.
As would the saliva from the person in front (as their mouth gets blown open) - if you sit behind the guy in front ;)
There's a lot of things they need to make sure the are OK from a safety perspective first - as this has the potential to end abruptly if they don't cover their backsides well enough.
Thats serious speed - with serious G's. Any more than that and there is the potential to cause some spinal injuries and cerebral problems if the riders aren't harnessed properly or have underlying medical conditions. And if there's a problem - stopping quickly at top speed probably isn't an easy option.
it takes stealth over 100m to run off the speed safely...
Not really.
134mph x 1.6 = 214.4kph = 214,400 metres
214,400 / 3600 = 59.55 m/s
59.55m/s / 2.5s = 23.82 m/s^2
23.82m/s^2 / 9.81m/s^2 = 2.43g
Not serious if your a jet pilot, but way more than normal people will have ever experienced.
Rita Queen of speed at Alton towers is quick...but not like this bad boy, I wanna go.
So soon we'll have 2 reasons to visit the 'ring,
