26 Mar 2009 at 19:25 #1 b0rn2sk8 b0rn2sk8 Soldato Joined 9 Mar 2003 Posts 21,000 If i buy say a 500GB Time Capsule, and in a years time i find 500GB is not enough, can i swap the hard drive to something bigger? Not fussed about warrenty or anything, i just want to know if its possible.
26 Mar 2009 at 20:25 #2 Vonhelmet Vonhelmet Caporegime Joined 28 Jun 2005 Posts 48,314 Location On the hoods 1) Silly question maybe, but why are you anticipating that 500GB won't be enough? 2) Why not buy the 1TB straight away? I think you can daisy chain time machines... I also think you can add an external USB hard disk to the port on it.
26 Mar 2009 at 22:23 #3 Combat squirrel Combat squirrel Soldato Joined 7 Aug 2004 Posts 11,461 Yes you can change the hard drive with abit of messing around, google it, many guides.
27 Mar 2009 at 00:08 #4 b0rn2sk8 b0rn2sk8 Soldato OP Joined 9 Mar 2003 Posts 21,000 vonhelmet said: 1) Silly question maybe, but why are you anticipating that 500GB won't be enough? 2) Why not buy the 1TB straight away? I think you can daisy chain time machines... I also think you can add an external USB hard disk to the port on it. Click to expand... Well i have a 500gb disk in my MBP, its running at about 60% now. My time machine disk is full. The 1T is well over £300, its a little steep. The margin must be insane on it. I was thinking get a 500GB now and swap it to a 2TB or whatever later. I know you can stick exta disks on the USB port, but its an exta box, an extra plug, wires etc, i gneally hate clutter. Found a guide, looks easy. Thanks
