Street Fighter (SFIV, SSFIV, HDR)
you can also cross them up to mess up their charge
Okay - have been reading the SF4 threads for a while and I have to ask - What does cross up mean? :confused:
And while we are at it - could some one else explain the oft used SF4 terminologies used at the moment?
Ta :)
Ta :)
cross up means that when you use a jump in attack, you time it so that you hit behind them. this means they have to block the other way to actually block it. watch our match together (ken vs fei long), i do it a lot in the first round
Ryu's one of the top tier characters in the game while Guile is pretty low down the list.
Treat the flash kick like an uppercut, easily punished and needs to be baited.
Unless you use low flash kicks, not invulnerable ofcourse but less exposed than the medium or high.
I have bought an octagonal restrictor plate now and should get it next week. Got it from a place in the UK and they have loads in stock. Not sure I can mention them here as maybe competitor - though I think they sell completely different stuff to OcUK. can never be to careful though.
ordered a Sanwa Octagonal Restrictor Plate GT-Y
If you want to let me know your e-mail I will send you link. You can edit out e-mail once I have it.
As for fitting it - check out youtube - loadsa vids there - looks easy.:cool:
hey M8 it says you aint got trust activated when i was trying to contact you, mine is so give me a bell on that, or just email [email protected]
the folks here are trustworthy enough :D
RaMDOM, you're not allowed to offer competitors through email, but in this case sites liek Gremlinsolutions and Arcadeshop are fine as they only sell custom joystick parts.
Okay cheers = everyday is a school day.
EasyG - it was from Gremlin solutions, listed under Sanwa Joystick accessories.
lk flash kick and lp dragon punch are both punishable just that the punish window is smaller :p
as for ryu vs guile, ryu turtles and zones better than guile... if you can't break him down up close then don't, you don't need to.
fireball > sonic boom (at range anyway)
dragon punch > flash kick
if you really want to get close then obviously don't jump if hes crouching. pressure him with block strings and bait out flash kick, or do some throws. once hes grounded you have much more chance of landing a cross up.
didn't you say you used gouken anyway? or was that more BS excuse's to why you lost your tourney matches?
Had enough, cancelled my Subsonic stick order and pre-ordered a Blaze Digital Arcade Stick from the same site.
Looks like EXACTLY the same stick, but with coloured buttons instead of square, triangle, etc.
Plus it's £5 cheaper than the Subsonic and they have a fixed date when it's supposed to be coming in (April 17th).
Hopefully I'll be able to mod it with some Sanwa bits, but even if not, it'll tide me over until something better becomes available at a reasonable price.
thanks for that m8, i've ordered myself a one, now the rather scary task of fitting it, think al watch that video about 10000 times this weekend.
Good games cav, although I expected you to be a lot better than that.
You really need to get a headset too.
Well Im not suprised considering I wasn't even putting in much effort into my game :p Hell I even pulled off some basic bread & butter combos on you which I was suprised about!
I do have a headset and will dig it out cause its getting annoying just sending messages now.
From what I have seen, you should be able to just open up the bottom remove the old one and reclip the new one in place. No glue or fittings required. Should not have to remove the stick mechanism at all I believe. Heres hoping :rolleyes:
Did not realise that these were so modifiable until today - have a TE on order but may cancel as this one should do me fine, and if it breaks - wack a new part in.
Can anyone tell me why I should keep my TE order, if I have the SE stick?
Fair enough, I'd appreciate you giving your all in future though as that's the only way I'll learn.
Well see I didnt think you were giving it your all when you selected Blanka (I was under the impression your main was someone like Ryu or Ken).
So I thought you were just having a messaround and plus I thought you said you were playing ResiEvil with your girlfriend so perhaps she was around and didnt let you give it yer all at the game :D
Next time I shall make it my duty to ensure you eat Guile's size 14s :)
Ever had one of those days where you can't play for poop?
Yep, that's me :(
seems experimenting has mixed me up a bit and now i never really seem to punish as best i can when i get the opportunity, so many times i've missed my chance due to pausing for a second to decide what to use.
