OCZ Gold 6GB DDR3 2000MHz PC3-16000C10 Low-Voltage Triple Channel Kit
Just £104.99 Inc VAT
The OCZ PC3-10666 triple-channel memory kit is designed specifically for the Intel Core i7 processor / Intel X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency. Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 2000MHz DDR3
- CL 10-10-10-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Currently the cheapest in the UK.
Buy Now.
- 2000MHz DDR3
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Buy Now.
