Putting a Lock on my door
Permabanned
30 Nov 2008
Manchester
I don't know if this is the place to post this. :rolleyes:
People like to wonder into my room when im trying to do stuff so i thought id put an end to that :D It's just what kind of lock do i need i suppose one from the inside will be fine.
My door
Left side; were it meets wall.
Right side (Hinges)
And the Top;
:cool:
looks like a simple bolt in the top would be the easiest and best option
you don't really have many options with that one - being the way it is against the wall
Only under the covers. ;)
Failing that... Chair under the handle? Works in movies. :p
chair with gas-lift is best.
put it under the handle, and lift the lever for ultimate doot jamming action.
I do it all the time when I am organising my pokemon cards in secret :cool::rolleyes:
Thanks for all the replys of people thinking i am .... :O I am shocked you think this and this isnt the case.
Thank you, R B Customs - for; looks like a simple bolt in the top would be the easiest and best option
Yeah, it's in a funny place really so just a bolt that goes up or down from the top.
Ahh..well maybe you should do that. Its cheaper than a lock, and I guarantee that once someone walks in and sees you on display they wont be walking in again :)
Hey I've had a crazy idea, if you know sod all about DIY why not ask a shop assistant in a DIY store!!
Nah thats just me being silly, makes much more sense to post a picture of your door online.
