192's core vrs 216 core?
752 core - 1566 shader - 1323 memory here with my zotac 216 :D
Is that on stock air? What have you stressed those clocks with and what GPU Vantage mark to you get with those clocks?
That must be at OC GTX 280/285 performance if my 260 (192) at 730MHz was pretty much same as a stock GTX 280. Nice job!
Well mines still on stock cooler on air with fan at 40%.
And my vantage score is P13861 - http://service.futuremark.com/compare?3dmv=926192
But my quad is only running at 3.4Ghz atm until I find the max of my card.
Once I have my max gfx overclock going to do a run at 3.8Ghz.
Testing is done by ATI tool for 20 mins for stability.
The cooler on the card isnt standard, more like the 295 cooler..which was nice, and i read someplace the clocks from another user with a 260/216, so i set mine to that, and had no probs at all. Idle its 39 , and about 56 max. I dont run 3d marks , pointless to me , i cant play them ..lol. Great card.
Well I;ve found my max with fan at 100% until I go to water later this week.
My weak point seems to be the memory.
Anyway, now stable at 783 core, 1584 shader but only 1152 memory
I guess all the heat from the core running so high is reducing the memory overclock?
