GTX280 + MONITOR! have couple of choices! (1920 x 1080 or 1680 x 1050 for gaming)
13 Nov 2008
Hello, just sold my 19" 1440x900!
so need new monitor for my pc (c sign)!
running with GTX280, I play All new games: NFS:Undercover, dead space, COD4, dawn of war 2, mirrors edge, wanted,..so...ALL
I have couple of choices:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-014-AS&groupid=17&catid=949&subcat=
one cheaper choice: for £104
Product Description Acer V223WA - LCD display - TFT - 22"
Device Type LCD display / TFT active matrix
Colour Matte black
Dimensions (WxDxH) 50.6 cm x 18 cm x 39.9 cm
Weight 5.2 kg
Diagonal Size 22" - widescreen
Dot Pitch / Pixel Pitch 0.282 mm
Max Resolution 1680 x 1050 / 60 Hz
Display Positions Adjustments Tilt
Colour support 24-bit (16.7 million colours)
Image Aspect Ratio 16:10
Response Time 5 ms
Image Brightness 300 cd/m2
Image Contrast Ratio 2500:1 (dynamic)
Signal Input VGA
Vista Certification Works with Windows Vista
Compliant Standards TCO '03, CE, TUV GS, ISO 13406-2, FCC
Power AC 120/230 V ( 50/60 Hz )
Power Consumption Operational 43.9 Watt
Environmental Standards EPA Energy Star
Manufacturer Warranty 3 years warranty
and HP 23" Dell S2309W Widescreen Flat Panel Monitor for £185
Full HD 1920 x 1080 Resolution – Enjoy cinema-quality movies at the highest resolution the filmmakers intended. Full HD also makes games, videos and digital photos shine.
Fast 5 Millisecond Response Time (Typical) – See crisp, clear images and minimize ghosting during fast-action video. Ideal for serious gamers and video editors alike.
1000:1 Contrast Ratio (Typical) – Sharpens HD performance with deep blacks, enhanced colour saturation and fine detail.
DVI-D with HDCP – Supports playback of protected high-definition content from Blu-ray DiscTM drives on PCs.
Dell-Designed Enhancements – The sleek black bezel complements most environments and home décor
so, which model is better for price? should I go for cheaper or is it worth to pay extra?
will GTX280 have power to MAX all games with this resolutions?
CHEEERSSS
go with a 1080p model, i brought a viewsonic 22" hd1080p earlier this week and my pc performs brilliantly with all the eye candy and max res, even fear 2 runs with full settings and gives me a minimum of 40fps, so your 280 will be fine.
I've got the 24" version of that Dell and it's just a superb monitor for the money! I'm using a less powerful card than you with a gtx260 and it's fast enough for that res :)
I'm using the Dell 23" your thinking about. Very good monitor nice and big, but id go for the asus simply because of the hdmi connection
Don't go for a monitor that has a res less than 1920* or your 280 will be wasted :p
Personally I prefer 16:10 (1920*1200) to 16:9 (1920*1080) for a monitor. 16:19 seems a bit squashed.
thanx for replies mates!
I wonder is 1920x1080 for 22" is good? my friend said that he read so bad reviews on 22" monitors with this resolution...?
HDMI is same quality as DVI, it just includes an audio signal too. As I said b4, Id recomend a 24" with 1920x1200, the one I first linked to is within your budget
It's personal preference, the pixels per inch will be pretty high, so text and stuff will appear smaller. Also your monitor isn't going to be very tall. personally I'd take a trip to a shop to see some monitors and see what you think.
Yeah it is a good monitor but has a slower response time.
I got my monitor for £155 including delivery from a competitor.
Which is the £50 cheaper monitor?
