- 19 Apr 2004
- London
Sounds quite normal, but I wouldn't be surprised if you can find some enthusiastic detailers nearby who will do it for a lot less!
You should see what Tangoman can do, he does a lot of S2000s mostly and for the work you have quoted there, minus the interiour, he was charging £150! For interiour and engine bay its £250.
http://www.s2ki.com/forums/index.php?showtopic=675691&hl=
His S2000 is spotless, never seen paintwork that looks so good! He can travel to your home also.
I've got a Porter Cable myself however I'd gladly pay a pro £400 to fully detail my car as the results are stunning, far better than I could achieve myself.
It depends on the value of your car and what your time is worth to you. You'd have to pay me more than £400 to spend an entire day detailing somebody's car that's for sure!
I still remember the job you did on your MR2 by hand which was impressive, I severely doubt being able to see £400 worth of difference if a pro had done it.
Thoughts?Thoughts?
I'd like to book you for the first weekend in August.Sod that, i'd charge no more than £20 and blow job, and probably still do half a good a job if you are lucky![]()
Even Dick Turpin had the decency to wear a pointy hat and a mask.
If your going to pay that much, go to the best
http://www.miracledetail.co.uk/
Dalton is the bloke that does the super expensive detail, but for £400ish he will do a pretty amazing job.
Got a quote:-
Exterior
• Hot Snow foam pre wash
• Bodywork washed with Meguiars Conditioning Shampoo and deep pile wash mitt
• Wheels treated and cleaned with acid free wheel cleaner
• Wheel arches treated and cleaned, High pressure hot pre-rinse
• Claybar cleansing paintwork then rinsing
• Bodywork Hand dried with Microfibre drying towels
• Machine cutting/polishing paintwork to remove oxidised paintwork and swirl marks
• Inspecting paintwork then removal of any remaining defects before glazing
• Zymöl HD Clense paintwork to remove oxidised paint and light swirls
• Hand application of Carnauba before buffing using Pakshak MF towels
• All mouldings, doors, boot and bonnet seals cleaned and dressed
• Tyres and alloys dressed
• Polishing of glass and chrome exterior trims
between £180/220 which I think it pretty good tbh, going to book Lee's next available date which he indicated should be mid April.
HEADRAT
Pics asap once its done please!
