Powerfull HTPC
5 Mar 2007
Macclesfield
How does the below look for a high powered HTPC?
What is the stock cooler on the Tri Core 720? Should I get a aftermarket Cooler, if yes which is quite and would fit the Antec case?
Is the Moatherboard / RAM OK? It will be used on a HDTV 1080p HDMI output.
Thanks!
Your basket
Product Name Qty Price Line Total
AMD Phenom II X3 Tri Core 720 Black Edition 2.8GHz (Socket AM3) - Retail £114.99
(£99.99) £114.99
(£99.99)
Antec NSK 2480 Desktop Case - Black/Silver (380W Earth Watts PSU) £86.24
(£74.99) £86.24
(£74.99)
Asus M3A78-EM AMD 780G (Socket AM2+) PCI-Express DDR2 Motherboard £70.14
(£60.99) £70.14
(£60.99)
OCZ Gold Edition 4GB (2x2GB) DDR2 PC2-8500 4GB Dual Channel (OCZ2G10664GK) £34.49
(£29.99) £34.49
(£29.99)
Sub Total : £265.96
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 15% VAT : £41.66
Total : £319.37
Starting off with the on-board, although i have a 4780 1GB in my other machine so might pop that in at a later date. (when i update my main gaming PC) I know the processor is overkill for a pure HTPC but I like the future proof side of it and have read good things about the Tri Core...
Cheers
You might want to consider throwing in a very cheap GPU to aid with the HD processing - something like
Sapphire ATI Radeon HD 4550 "Low Profile" 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
No-use for gaming but useful in a HTPC
My Dads got a 780g Mboard and it does 1080p BluRay no problem.
Anyone know a good cooler (small) or can anyone comment on the stock cooler, HTPC would like it to be quite.
I look into the size of the case (good point thanks) regarding Graphics Cards
Thanks
Also check the height for a CPU cooler I have a thermaltake bach and you havent got a huge amount of headroom.
Was thinking of the Scythe Mini Ninja CPU Cooler (Socket 478/754/939/940/AM2/LGA775) I assume AM2 coolers fit AM2+ Boards? Is this a good quite cooler, or is the stock one OK?
Cheers
