name of the part needed
3 Dec 2002
Groovin' @ the disco
Hi
my rear screen water jet thing is not working on my a3, I've taken the cover of the wiper and saw that the holes where the water comes out is blocked on the little bit of plastic. After pining it and cleaning it; it still not working. Whats the name of this bit of plastic? I've tried water jet, water spray, washer jet ect, and I can find it on fleabay.
Thanks
Before going to buy anything. Make sure the rest of the system is in check!
the water pump works as once the plastic is removed, I have a super soaker 500 water gun at the back of my car. hmmm maybe I should leave it removed so I can spray the people behind me?? lol
I'd say washer jet. Stop fannying about with ebay when it'll only be a couple of quid from Audi.
I had this happen on my S3. Ended up being the pump. Can also be a disconnected pipe. You can check the line by taking the trim off the boot lid.
Sorry, I completely missed this post. Just find your local stealer. It's not going to be £100 for a plastic washer jet. It'll be a few quid max I'd have said.
