- 18 Mar 2009
- Indiana, United States.
How long will that be? You can't throw a screenie up here to make me wish I had bought a nocturaWhen my new motherboard comes yes.
I suppose that points towards not enough air entering the case via the front fan?
Either way, that is quite hot...
V8's do tend to have lumpy idles though!![]()
When my pc case is open it drops mine 4c as well. that is normal. does your psu rest at the top? mine does and it really spews out the heat. What kind of temps were you getting at stock speeds with the stock fan? That is the question I want to know. I think that would maybe help narrow down the real problem.
V8 works great for me, the fan seems to be engineered for quiet rather than performance but even then it works pretty great, with a couple of simple airflow mods it will keep my Q6600 under 55C even with 1.6 vcore.
Try to set your voltage to 1.18 or 1.15, as opposed to auto. You should be able to have a stable 3.2ghz setup right at one of those so I would imagine stock speeds would be fine too. See if that doesn't lower your temps, although still doesn't make sense for them to be that hot unless somehow your auto setting keeps upping the voltage during high loads which I guess may be a possibility.
Those are great temps for 1.6 vcore, what clockspeed are you running Rroff?V8 works great for me, the fan seems to be engineered for quiet rather than performance but even then it works pretty great, with a couple of simple airflow mods it will keep my Q6600 under 55C even with 1.6 vcore.
ok i lower down my vcore to 1.18 and my temp went down a lot 58c run prime95 10 min to. and i put my 2 ati fan to 60% speed![]()
i just highered my voltage back to 1.25 and my temp went up to 60c. run prime95 for 10min looking good now
If you are doing 58c in prime95 that sounds much better. You could probably set the qpi (bclk) to 160 instead of 133, and get 3.2ghz without having to raise your voltages and that should be a stable setup. Temps should not increase much either, but they may a little.
Really I just wanted to never hit over 75 per core in prime95 cuz with tjmax at 100 that's still 1/4 under that. In normal use, I would never max out all 8 threads so temps would be fine if I wanted to go 4.2ghz for my everyday use. I just would probably crash in prime95 without raising my voltage, which would in return put me closer to 80c under 100%load.
ok am running (bclk) to 160 mult 21 and my clock are on 3360mhz max temp 69 at full load useing prime 95 for 15 min.. think temps to high for 3.3ghz
