Hello there,
I am new to these forums so please forgive me if I'm posting this in the wrong section.
I've just built a new rig, and I need help deciding if I have a hardware problem or not. Firstly here are the specs:
-Asus M4A78 Pro 780G
-AMD Phenom II x4 940 (not overclocked)
-Saphire Radeon 4870 x2 (GPU 790mhz Memory 990mhz overclocked, 50% fan speed)
-Coolermaster Real Power 700w Modular Power Supply
-Kingston HyperX 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz (not overclocked)
-Western Digital Caviar Blue 640GB SATA-II 16MB cache
-Vista Home Premium 64bit
-Samsung 20" LCD (1600x900 max res)
I will be getting more ram at the end of the month. Hopefully up it to 6GB
Vista is up to date, running in high performance power settings, I'm using the latest catalyst drivers, havn't downloaded anything for the bios, but I have turned OFF the onboard GPU.
So, the issues I'm having:
-1st of all, and quite a big issue, the copy of 3D-Mark that came with the 4870 x2 gives me a score of a little over 11,000. I had seen reviews etc that were getting scores of at least 20,000 with a 4870x2 and a quad core proc, so its very alarming to be getting a score this low. The whole test seems to go quite slow in terms of FPS, at around 20-40 average, even as low as 5 in some parts. The slowest tests were the physics (planes flying through hoops, and the moving flags) they were un-watchable frankly. Lower than 15 fps.
-Although the horrible 3D-Mark results, I tested the Crysis demo which actually runs quite smoothly on high settings with max AA. On very high settings its just about un-playable, probably between 8 and 20 fps, and I havn't even turned AA on for that. Overall in terms of speed, it's not too bad, but I was expecting to be able to play it on max settings, and I still want to, so I am dissapointed.
-Also on the Crysis demo, on either high OR very high settings, I'm getting horrible flashing graphical errors in the clouds and in far away bushes and trees. This gets steadily worse throughout the demo too, and towards the end where you download some intel from a computer it looks ridiculous filling the whole sky with flashing and even the image that was just on the computer screen that you downloaded the intel from.
-Other demos run fine like UT3 (but I know that demo is limited to medium settings), and the 3 demos that came wit the card (they're old though). I installed the first F.E.A.R game, and I should be getting over 100 fps on max, but I'm only getting between 35-60!
-Out of gaming now, generally the pc seems to do everything slower than I was expecting. Like installing, loading up programs, playing music... My older PC is using an Athlon 64 3400+, radeon 9800 pro, 1 GB RAM, and it just feels like the same speed as the new rig... Obviously not gaming, I'm just talking general PC tasks.
So I am at a loss.
The GPU seems to be doing it's job, both GPU cores seem to be on as the auto-tune on the catalystCC tuned 2 GPUs.
The processor seems to be running the 4 cores (based on the ctrl+alt+del system performance tab), and I used CPU checker or whatever it's called and that said it was doing just over 3 ghz which is correct.
The hard drive has many reviews saying it's fast, so I don't think I've chosen a bad drive.
2GB of DDR2 isn't a lot, and I will be getting some more soon, but I don't think that alone would be giving me such poor performance.
The on-board GPU on the mobo is turned off (it was on the first time I tested which produced loads of atifacts but I quickly fixed that problem)
I'm assuming that the PSU is sufficiant, I was under the impression that 700w would be enough.
So thats about all I have to report (phew!). I would appreciate any help anyone can give me. I've spent quite a lot of money on this rig and I want to see it running how it should be.
Thanks!
So I am at a loss.
Thanks!
How much more could I potentially get out of it though?
