- 15 Aug 2006
- Leicester UK
You might find that you're reported for several offences and then based on the merits of the case (or lack of), then some will be dropped. My only advice would be to go and see a local (to where you were pulled) criminal lawyer IF you get a summons. It won't be that expensive but they have regular contact with the decision makers and will be in the best position to represent you. But until that happens, forget about it and deal with it, IF it comes to anything. Nothing else you can do really.
