- 19 Nov 2008
I always se people of this forum saying that it is crucial to have a 120.3 rad for any decent water cooling setup, I don’t think I will be able to fit on in my case and don’t like the idea of it being outside the case, how would a wc setup with a 120.2 rad compare to a good air cooled setup or to a 120.3 rad.
I was thinking, would 2 X 120.2 rads be better than one 120.3 rad it will have more surface area to cool the water? The rads would be strapped together and treated as one thick rad with a push/pull fan setup, using ~1200rpm fans.
Taking a brief look at the dimensions it would be about 17cm wide, this if from using 2X25mm fans(120mm) and 2X60mm rads (120.2).
My main concern with this setup is it could limit the flow of water, but this should be soled easily be using a good pump?
If this setup is feasible and would offer performance as good as a setup using a 120.3 rad I may be getting watercooling shortly.
