Landlords agency won't allow a sat dish
Permabanned
30 May 2006
I recently moved in to a flat and I want to setup a satellite dish on the balcony. The dish will be mounted on my base therefore no damage will be done to the property at all other than the hole i need to open to pass the cable inside. I contacted the agency that manages this building and they said no satellite dish is allowed and this is not negotiable at all. Then I read the contract i signed and it says:
Aerials: Not to erect or permit to project outside the property any wireless or tv aerial or satellite dish or other construction without: a) landlords consent not to be unreasonably withheld, and b) landlords agreement to the form of installation.
From this it doesn't appear to say "You can't have sat dishes". It appears to suggest that it would be negotiable which is what I thought when I signed.
Can someone explain to me what the "not to be unreasonably withheld" means? Can I win this case?
It means you can put the dish up as long as there is not a reasonable argument not to do so.
I suggets you request what these reasonable arguments are.
I would interpret that as it he cannot just turn around and say "No".
Does not mean he can revoke permission on the criteria you are suggesting to him though. Do other people have the same setup you are looking at?
it depends I guess, if it will make a noticable asthetic change they are probably within their rights to withhold permission. Have you confirmed you can actually install it on a balcony not on their property but your own base so it can essentially be removed when you leave easily, or are you hoping it will work there. If hoping, you might find that they can't get a signal there and it has to be higher or in a different location, they might have looked into it with previous tenants and found out it has to go somewhere very visible.
they might even have removed a previously installed one and be assuming the location was the only place they could install it. Its worth asking/persuing as it might be nothing more than a misunderstanding. Check if any neighbours have them, if they all have one then their argument gets weaker and their refusal might be more easily deemed unreasonable. Block of flats or just floor of a normal house? maybe theres a dish for the block you can also use?
A lot of landlords and agents won't allow satellite dishes for cosmetic reasons, and this is generally seen as a valid reason. This isn't limited to specific properties either: some areas of Westminster don't allow satellite dishes on whole streets for exactly - and only - cosmetic reasons.
You could put one up anyway but it wouldn't be worth the hassle if the agents find out. Get cable or something instead.
If it states in the Convenant that no satellite dish or any external fixing allowed then the landlord can't say yes even if he wants to. Specially when its a flat !
Covenant?? I didn't realise the contract we were discussing was the 10 commandments!
We have a dish up and it says on our contract you cant have one, and i own the house im not even renting! I think its just a clause in most house deeds now, to try and keep the street looking nice. Im not allowed to paint my front door.
A deed for an owned house is very different to a recently drawn up tenancy agreement. In a private let, the house is owned by the landlord - not the tenant - and the tenant is subject to the stipulations of the landlord as monitored by him or his agents and signed in the tenancy agreement.
