Thermalright copper 120
19 Nov 2008
Thermalright Ultra-120 Extreme Copper.
any of you guys seen this thing, its a beast. weighs 1.8kg of pure copper.
has anyone on this forum got one :)? wonder if it is a lot better than the normal version, if the bottom is not lapped well, all that money...
looking at what people are saying about it and i wonder if motherboards will support the weight if standing upright.
It looks lovely, but I wouldn't want that much weight hanging off the motherboard, and also it doesn't seem to perform much if any better than the aluminium finned one - presumably the heat getting from the base/heatpipes to the fins is the limiting factor?
they say it is only intended for motherboard that are mounted horizontally.
it is also a limited edition and only 3000 were intended to be made ( dont know how many were atuchaly made)
i always think that when looking at all heat sinks, imo they should start of with a solid block of metal and form the fins from this this ofc would be very very heavy and expensive tho.
a couple of pipes dont seem to transfer enough fast enough and also look at that design i bet only 1/3 of the fin closest to the pipes will be transferring heat the center of the fins will prob be 1-2degrees over room temp.
also about the weight, one guy designed a Perspex bracket to hold the weight of the MB. got a clock of over 4ghz on a 920 i7, that is rivaling water cooling but i bet it was noisy.
damm that looks sweet and how much does it wiegh? :O O_O need hell of a mounting system for thatO_O
can you lap a heatsink, assumed it was only for cpu chips.
ofc i know this is only a joke
Of course you can lap a heatsink. The TRUEs are infamous for their concave bases (allegedly to make them fit better with the convex IHS on chips) so people just lapped both their chip and their heatsink, et voila, perfect contact.
ah cool, would this be done in the same manner as the cpu would be then?
