Anyone else get the same in Win7 ?
Somethings not right here, go through the AMD site, it takes you to the 9.4's on the game.AMD site, but if you go straight to the game.AMD site, it says they are the 9.3's, but when you select which set to download, it says 9.4's.
EDIT: Just unsintalled them and found the problem, its only installing the CCC for some reason, as thats only what came up when the list was populated.
EDIT2: Yep, just checked Device Manager, and the WDM 1.1 driver is on (which reisntalls when you restart after uninstalling), so the 9.4 driver didn't install for some reason, just the CCC, so trying again.
EDIT3: Nope, wont install the driver, just the CCC, Device Manager still says WDDM 1.1
