Windows 7 build 7077
you can keep all your programs when you upgrade the build right? or is it a full re-install job?
All i had to reinstall when i upgraded was my gfx card drivers, and ive got games and all sorts of stuff on it, but its worth a try anyway, as before you start the upgrade, it will tell you what won't work and so will need reinstalling, so if it comes up with a load of your programs, don't bother doing it. :)
my next upgrade will be the RC 7068 seems pretty damn stable tho considering i upgraded from 7000 (only thing thats annoying atm is windows sounds disabled yet there still there and working :( )
was wondering if anyone has played a game with pukbuster on this version and if so are they getting kicked thanks,only reason i went back to vista
Build 7077 does not need a serial. Does this indicate anything are we getting near the very end of the builds?
What do you mean doesnt need a serial??
Yes it does, if you mean to install, none of them did?? :confused:
But to activate and continue to use it past 30 days you need a serial
