Upgrading sky to sky+ - easy job?
Commissario
23 Nov 2004
Herts
Getting a sky+ box from Mr Thundycat on here over the weekend and planning on installing it beginning of next week.
He kindly pointed me in the direction of this kit and for one minute I don't misjudge him but is it all I need to get the new sky+ box up and running?
And overall is the whole job generally an easy one? The sky engineer put some brown putty-like stuff in the wall to cover up any gaps between the cable and wall (on the outside) - can this be removed and re-applied or do I need to purchase some more, and if so what's best?
Any input is appreciated :)
Yep, it's as easy as that. When you get it all connected up you'll need to ring Sky to enable Sky +.
The stuff in the hole can easily be removed and filled with some more. :)
Don't forget you'll also need sky to pair your existing card with the new box, the job itself it a piece of cake, you'll be up and running in no time.
