PC8500 Ram Choice
31 Dec 2005
N.I
The motherboard will either be a P5Q-E or a Ga-EP45-UD3P. More in the direction of the P5Q-E
Question is, what would be the best choice between:
4GB OCZ Platinum/Reaper
4GB Corsair Dominator
To be honest the Dominator would make it more convenient as they are easier available to me, but I want to check which would suit the choice of boards for overclocking and compatibility wise.
Also is there any real difference between the platinum and reaper, apart from a few quid?
Will they still manage as good of an oc as the other choices?
And also, has anyone any input on the dominators regarding the P5Q-E? as they're seeming the more convenient option for me atm.
I have the P5Q-E (last week) plus the Kingston HyperX 4GB (2x2GB) DDR2 8500C5 1066MHz Dual Channel. Got them last week as well, £38.00 delivered. I have a Q8200 2.33 @ 3.01. Will O/C I have seen the Ram hit 1111mhz.
