- 5 Mar 2009
- North East
there was a article of tomshardware sorry if that against rules that said unless you do major work on it there is no difference atall between a 2gb 32 bit system and the same but 8gb on a 64 bit system as there isnt anything unless you use a lot of professinal software that can utilise it in windows
when u have adobe PREMIERE, AFTER EFFECTS and PHOTOSHOP open all at the same time it does
