BFG OC2 285
28 Nov 2004
hi there i purchaced 2x BFG OC2 285 cards on saturday.
for the life in me couldnt pass vantage when in sli.
tried both cards 1 would pass the other 1 wouldnt.
i have tried down clocking both cards from gpu 691-680 shader 1566-1552memory to 1273. is this normal for sli cards.
im getting no artifacts and cards under load r 80c. please help.
Do you mean by this that you tried each card individually, one would run fine at the speeds that BFG set, and the other would crash? If so, contact your vendor and tell them that you bought a card which isn't running as it should, they'll replace it.
