My god this is downloading so slowly. I wish there was a version up on usenet.
PERFORMANCE-WARNING:
The Orangebox/Source Engine is getting outdated and performs poor compared to newer engines like the Cry-Engine or the Unreal-Engine.
It's almost impossible to get good framerates with enhanced viewrange, hires-textures and high polycount.
Therefore prepare yourself for fps below 40 in some open areas, unless you're using the latest NASA supercomputer.
Currently i have reached the source-engine limits in almost all areas. Unfortunately the limits are quite low. The current build of the source engine can't render detailed open areas or nice foliage without hitting this limits.
(Compared to the Cry-Engine: Source engines 100 % entity limit equals approx. 5 % of the Cry-Engine limit)
I'll take a break now, hoping the next engine version will give the possibilities, i need.
I've never played Half Life and been thinking of buying Orange Box for a while. What's EP1 and EP2?Downloaded all the following at over 1.5MB/s at college, so they're not capped (other people were using the connection, dammit!).
v9.0 BASE: http://games.on.net/file/23189/HL2_FakeFactorys_Cinematic_Half-Life_2_Mod_Base_v9
v9.51 UPDATE: http://www.infortech.eu/paulus_cobris/CM95-1_UPDATE.rar
v9.0 HD Addon: http://games.on.net/file/23190/HL2_FakeFactorys_Cinematic_Half-Life_2_Mod_Addon_v9
Install order
1. 9.0 BASE
2. HD Addon
3. 9.51 UPDATE
These are the ones I'll be downloading:
v9.5 UPDATE: http://games.on.net/file/23250/Fakefactorys_Cinematic_Mod_V9.5_Update
I'll install them in that order as well.
Quite possibly, even the creator of the cinematic mod has said that he's pushed the Source engine to it's limit which is why it lags.
HD-ADDON USERS:
Apply this patch *AFTER* you have installed the HD-addon. If you ever install the HD-addon after the hotfix, you MUST apply this hotfix again. For taking
effect reselect and install the new models with the Character Pimper.
CM 9.51 (Hotfix Update)
+ Added new HD Alyx model (Adriana Lima style) with realistic (mavity influenced) hair motion
V14 tagged model is a WIP/TEST
V16 tagged model is a final model
* Hint: Not suitable for fans of the battle-worn VALVE style.
+ Recompiled Monk / Barney / GMan models, fixing some Bone-Errors
+ Added new HD Mossman model (blonde again)
+ Added new HD Barney model (closer to VALVE original)
+ Added GMan-Hybrid Model (old VALVE mech with Hires-Facemap as seen in older versions of CM)
+ Reworked Character Pimper for multiple model variations in "Maincharacter" section.
+ Recompiled the maps with higher precision lightmaps and per-vertex-lighting accuracy on props
- Fix: Worked around an old Valve Bug in Response-System. Alyx will now allways react if you are staring at her for some time in Non-Combat situations. Reaction depends on her actual condition (relaxed, stimulated, alarmed)
- Fix: Portuguese subtitles
- Fix: Areaportal error in map prison_05
- Fix: Terrain hole in map coast_03
- Fix: Ugly skybox and heavy performance drop in canals_13
- Fix: Wrong rendered blood splashes
- Fix: Wrong LORES-Civilian models (if HD addon was installed)
- Fix (hopefully): Twin-Alyx in prison-levels
- Fix: Slowmotion when Quickload (F9) was pressed
- Fix: Tons of other small glitches
I got mine off usenet. Search newzleech for cinematic modAfter downloading this on and off for a few days at a painful 5-55Kb/s I went to resume it again this weekend only to have it fail the resume after about 3.3Gb. I was fuming!!
Why is this not up on Usenet? Or if it is, can anyone point me in the direction of a .nzb for it please?
Where can I download this with a respectable download speed?
Still waiting for the Black Mesa mod... I have held off playing through HL1 at all!!![]()
