Did you ever get any of the Bridgestones mate? I'm thinking of trying the RE050As
Yeh had them on the front, lasted about 6 months and were great in the dry but got a bit skitty in the wet once they wore down abit. Replaced with Yokohamas now.
Just had 4 of the RE050As fitted to my Octavia vRS (so a little larger than your requirement).
Very impressed so far - certainly a lot quieter than my old Dunlops.
I'm also getting a much smoother ride (although that could be because my Dunlops were extremely worn).
They also feel nice and clingy around the corners.
I bet you aren't going to have to pay £115 per corner for your RE050As
Ooops - just noticed this is a major thread revival.
Cheers, how are you finding the Yoko's now? Which ones are they?
