24" best budget
18 Aug 2004
The Toilet
Samsung SM2433BW
or
OcUK Value 24" Widescreen LCD Monitor
or
Iiyama ProLite E2407HDS 24" Widescreen LCD Monitor
Cheaper is definately better, the sammy is in B-grade cheaper than the others, its to plug into my laptop to watch TV through with a tuner I plan on buying, bit of guitar hero too, eventually it will end up being my PC monitor by Xmas or so, and Ill probably buy a 32" or 37" TV....
Or would I be better off just getting the 22" asus thats in TWO?
Moving from 19" Syncmaster 913n (1280x1024)
And my Laptops a dell 15.4 1440x900
so either way im taking a big step up.....
theres a t240HD too, obviously more expensive but its got its own tv tuner, which has its pros and cons, obviously its not going to mean I can have 2 things playin at once(its not a dual tuner) and I wont be able to record the tv on laptop if im out/busy.
i've been considering the T240HD too......seems a decent screen for the budget but i've seen mixed reviews.
I'd want to game on the XBOX as well as inputs for my pc.HDMI would be a plus for me too.
What inputs do you need?
My laptops only got VGA, but it will eventually be used with my pc, so DVI or HDMI.
Wont be used for any hardcore gaming or anything, im not that fussy, long as my films and tv dont look crap, at end of day im hardly used to brilliant screens.
i know what you mean, i've still got a 19" CRT and a cheap 19" lcd by the side of it.
I'd want to watch films and play xbox on top of the usual photo editing and internet browsing. some people say it's a great screen, others say the colours look washy etc.
annoying, think I might just order the 2433, any idea when the cutoff for next day delivery is? tried to search for it cos id seen another thread asking about it other day but no luck
o well ordered the 2433 from b-grade, needed to get something before i head back down to work 2moro night as i cant get things delivered darn sarf
