16 Apr 2009 at 18:30 #1 J1234 J1234 Soldato Joined 16 Oct 2005 Posts 13,793 Does anyone know if this is possible? I want to reset the play count on my entire library.. Thanks.
16 Apr 2009 at 18:32 #2 J1234 J1234 Soldato OP Joined 16 Oct 2005 Posts 13,793 Never mind, Google reveals all.
16 Apr 2009 at 20:31 #3 Feek Feek Commissario Joined 16 Oct 2002 Posts 344,136 Location In the radio shack I use one of Doug's scripts to allow me to tweak play counts.
17 Apr 2009 at 16:29 #4 Rameses Rameses Soldato Joined 18 Oct 2002 Posts 8,453 You trying to hide the fact you've had S Club 7 on repeat arnt you?......
17 Apr 2009 at 18:55 #5 Deleted member 651465 Deleted member 651465 Justin said: Never mind, Google reveals all. Click to expand... Care to share the solution? I usually delete the library.xml file and rebuild.
17 Apr 2009 at 19:04 #6 Feek Feek Commissario Joined 16 Oct 2002 Posts 344,136 Location In the radio shack Here's the script I use
26 Apr 2009 at 00:41 #7 J1234 J1234 Soldato OP Joined 16 Oct 2005 Posts 13,793 EVH said: Care to share the solution? I usually delete the library.xml file and rebuild. Click to expand... Show play count, then select all songs, right click > delete play count. Simple.
