I've got an 8800 GTS 320 and I can run all Source engine games in 1920x1200 with all settings to maximum and AAx2. COD4 runs fine in the same res with maximum settings.
Aside from a few poorly optimised games like Crysis and GTA IV, most decent graphics cards from the past two years can handle just about everything in 1920x1200.
I was playing portal on a friends pc, gts 320 at 1650*1050 and there was noticeable lag without any AA. You're either joking, lying or have some kind of superkarrd
Perhaps the rest of his computer sucked. I have L4D in 1920x1200 with 4xMSAA, Anisotropic x4, Vsync disabled, multicore rendering enabled and all other settings on very high/high. I play TF2 every day on the same settings, except with 2xMSAA and Anisotropic x2. Both are perfectly playable.I was playing portal on a friends pc, gts 320 at 1650*1050 and there was noticeable lag without any AA. You're either joking, lying or have some kind of superkarrd
The Source engine, although updated every now and again, is hardly cutting edge. It runs in 1024x768 with medium details without AA/AF on a Radeon 9700, and my 8800 GTS only struggles with it when I raise AA over x4. COD4 is just a game that runs extremely well for whatever reason - I slightly reduced my AA when I went from 1280x1024 to 1920x1200 and the performance drop was minimal.The GTS 320 struggles even at 1680*1050 due to the low VRAM, I used to have one. Modern games with that card at max details at 1900*1200? Not a chance.
TJM said:Aside from a few poorly optimised games like Crysis and GTA IV, most decent graphics cards from the past two years can handle just about everything in 1920x1200.
There's no way the GTS 320 can handle just about everything in that rez... it used to struggle for me at 1680*1050 with AA on. VRAM is a huge limiting factor for this card, many tests and reviews have proved it conclusively.
I didn't say the 320 could run almost everything with max details and AA at 1920x1200, I just said it could run them in 1920x1200. I gave examples (Source games, COD4) where it doesn't struggle at all even with high details and AA on to make my point - you certainly don't need two mid/high-end cards to play in 1920x1200, which was what the OP was asking.There's no way the GTS 320 can handle just about everything in that rez... it used to struggle for me at 1680*1050 with AA on. VRAM is a huge limiting factor for this card, many tests and reviews have proved it conclusively.
