Well in my view the problem with my mates set up, was the amp is not good enough to drive the speakers.... He demo them in the shop with a much bigger Pioneer amp, and was impressed.
Well the other bigger issue for me is music, and the simple fact these single box solutions are not getting anywhere good enough to compete with 2 channel stereo. This being where my Linn "multi channel" pre will take on all and come out on top. Then it does a superb DD/DTS job, and will accept 5.1 in from a BD player should I want.
So for me it was justifiable to spend out, as it's used for movies and music, which would be everyday.
So I just need to add an Audyssey processor into my system .... How much are they ?????
That said if you set you room up properly, positioning speakers for best music performance, and add some room correction as I have done, it gets pretty dam good....
