Using Autoglym on Bathroom Tiles
29 Sep 2004
Wilt of the Shire
Just had the bathroom tiled and the tiler said that we should use autoglym on them to keep them nice and shiny and easy for cleaning. I take it means using the car polish! Anyone else use this stuff or anything else to clean their tiles (apart from the normal household cleaners)?
Yes he means the car polish and it's also great for polishing glass as well.
Lots of car cleaning products had alternative uses before the car was invented and have been implemented over into the car industry. Collinte wax was originally designed as an electrical insulation and is now solely used for cars.
Thanks, off to buy some and impress the wife with the shiny new bathroom!
You need some cutting compound and a porter cable run over it first.
WE WANT FULL GLAZE CORRECTION!!1111oneone!!
Don't forget to use back-to-white grout brightener too.
:D
