Hey all thanks for checking out my post, I hope you can help.
For quite a while now I have been recieving these random BSOD with various error reports I will list them below but I guess my system spec would be best first. (sorry if this in wrong place to post)
Spec:
Operating System Microsoft Windows XP Professional
OS Service Pack Service Pack 2
CPU Type DualCore Intel Core 2 Duo E6750, 2666 MHz (8 x 333)
Motherboard Name Gigabyte GA-N650SLI-DS4 (3 PCI, 2 PCI-E x1, 2 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN, IEEE-1394)
Motherboard Chipset nVIDIA nForce 650i SLI
System Memory 2048 MB (DDR2-800 DDR2 SDRAM)
DIMM1: Corsair XMS2 CM2X1024-6400C4 1 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-4-4-13 @ 270 MHz)
DIMM2: Corsair XMS2 CM2X1024-6400C4 1 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-4-4-13 @ 270 MHz)
Video Adapter NVIDIA GeForce 8800 GTS (320 MB)
Seagate Disk Drive ST3320620AS (320 GB, 7200 RPM, SATA-II)
Seagate Disk Drive ST3400820AS (400 GB, 7200 RPM, SATA-II)
PSU Hiper R series 580watt
(I can provide the full report from EVEREST, if needed)
Ok back to the probelm I have been getting these very random BSODs which seem to have no pattern to them, they usally vary in errors and dont happen at any specific time or point.
BSODs
-STOP:0x0000001A (applied a windows update)
-Driver_IRQL_NOT_LESS_OR_EQUAL:0x000000D1 ( updated rtkhdaud.sys)
-0x0000007F
-STOP:0x0000008E (win32k.sys was mentioned with this bsod)
After seeing these I tried various tests, firstly was memtest86+ I ran this for 26 passes with no errors. So im not sure now if my RAM is faulty.
Using speedfan I seen that my CPU temps were pretty high (44-46c normal, 64-65c 100% load) I am planning to replace the current intel stock HSF. could overheating be the issue?
I also checked HDD using the speedfan SMART utility but again came back with "ok" results so that should not be a probelm. I have noticed that my HDD does make a lot of noise (grinding, from time to time and once even a clicking sound).
So does anyone have any advice they could give or point me in the right direction to fixing this probelm? Any help is really appreciated!
Not sure if this is relevant but could be worth adding.
[Im not sure if this will help but speedfan does show some voltage information:
Vcore1: 1.14V Vcore2:1.94V +3.3V: 3.36V +5V: 4.89V +12v:0.45V
-12V: -16.97V -5v: -5.41V +5V: 5.16v Vbat: 3.10V]
Spec:
BSODs
-0x0000007F
