where can i buy air filter style foam
10 Jan 2009
hi all, i need to replace some of the foam from the front of my coolermaster case, does anyone know where i could get some from?
thanks
Not too sure what you're on about mate, but have you tried asking Coolermaster? You never know, they might send it you for free.
or go to a fabric shop, sure they will have somthing suitable - probaly get some off-cuts for free or pretty much nothing, somthing ilike some thin wadding type stuff.
it got lost for a old case that i havent used in a while. might try coolermaster, but the fabric shop could be an idea i think i know of one :)
There's a guy on the bay that sells rolls of filter wool meant for fish tanks. He sell's it for £5.99 including postage, for a roll that is 72x18 inches. I use him all the time as he is so much cheaper than buying the proper filters. I use the same stuff as a filter in my watercooling radiator box. Not sure if i can mention his user name on here though. Do a search on the bay for pond filter roll. ;)
