Cool.
I'm not holding me breath, may just pay the £10 can't be bothered to wait for a reply from a letter!
Cool.
Download this:
http://koushikdutta.blurryfox.com/G1/DREAMIMG-RC7.zip - This is the Original STOCK firmware.
Rename to update.zip and place on your SD card and flash it as you did the hacked firmware.
I would suggest doing a "Wipe" before flashing. This will obviously delete any downloaded content/customisation.
After a while you will be given an over the air update. Job done.
All apps can be got from the 'Market' it's like Apples App Store but more open (Wifi tethering programs excluded) There are LOADS of programs there, I mean LOADS!
Ones I quite like are:
Useful Switcher - Great for turning on/off Wifi/BT/GPS. Also has a 'torch' and more
App Manager - Installs programs from SD and also uninstalls too
aTrackDog - Checks for updates for your installed programs
Movie Finder - Finds local Cinemas and movies
My Tracks - Logs your location via GPS then you can upload straight to Google Maps. AWESOME
NetCounter - Tracks your internet usage
PowerManager - Allows you to set profiles depending on battery condition etc. Good program
it should just pop off, nearly always think its going to snap in half when i remove it but its fine.
Yes, but the one your on about is RELIABLE with many people using it reporting no problems as far as I know.
Ive used them twice and can vouch for that. Second time, I goofed up and they were still helpfull.
http://www.unlock-tmobileg1.com/ - VERY Reliable - £16.99
http://unlockg1mobile.com/ - Is $19.99 which is apparently around £13.43 according to XE.com currency conversion.
LOL @ these cowboys: http://www.unlocksearch.com/
They charge £2.99 to tell you WHERE you can go to unlock your phone - ROFL.
Just used a guy off the bay, £13.00 paid got a mail 10 minutes later with a code
All unlocked and running my Orange sim in it now![]()
One thing though I don't seem to have the 3G symbol like I did when I had my work T-mobile sim inserted?? Is there any settings I need to add for an Orange SIM?
Sounds like you are not receiving 3G. Probably APN settings.
Hi mate
Thats exactly what I need, any ideas where I can get the correct settings? I have unlimited web internet on my account and have had for a while?
Try this: http://forum.xda-developers.com/showthread.php?t=475564&page=19 (Last post)
