- 20 Mar 2007
- Norwich
Is it possible to get a sun tan/burn if you're behind a normal double-glazed window?
Just curious.
Just curious.
Window glass does a fairly decent job of screening the UV-B (burning) spectrum of light. While other substances do a better job, enough is screened to usually prevent the chance of sunburn. As for double pane windows, the more glass the better and tinted glass prevents even more. However, there are UV-B and UV-C rays as well. UV-A type rays are emitted by the bulbs in tanning salons and can produce certain types of cancer. These, obviously, pass through glass, but don't usually burn. UV-C rays don't reach the earth's surface, since they are blocked by the ozone layer. The new generation or Low-E glass windows are superb and designed especially to inhibit the UV waves...
You won't get a sun tan but you can burn your skin.
KaHn
If you can burn, you can tan.
Why you ask for?
Does the sun shine on you through the window at work?![]()
Not really. I usually burn, go red, peel and be white again![]()
Why you ask for?
So you can't get sunburn, but you can do long-lasting damage to your skin.
