I´ve been in touch with them throughout the week, for those of you interested here are the latest developments :
Sent: Monday, April 20, 2009 5:26 PM
To: 'F. Sgar'
Subject: AW: Refused RMA due to dust ( Europe) S/N: 60883143039xx
Kyle,
this issue had been discussed in detail. Joe Darwin received an email from me today regarding this issue.
Fact is, that the board got damaged out of neglect - the neglect to keep the working environment of his PC clean. DUST is one of the biggest enemies to electronics.
And honestly, I've never seen such a ffilthy board before.
It is NOT about cleaning his product, it is about operating his equipment in an atequate environment - which this product was most certainly not
Von: F. Sgar [mailto:
[email protected]]
Gesendet: Montag, 20. April 2009 18:21
An: Peter Tersluisen
Betreff: Re: AW: Refused RMA due to dust ( Europe) S/N: 60883143039xx
Well,
I am sorry, but I still dont understand this whole issue of the dust. You mentioned you cleaned it an realized the fan motor was burned on your last email.
Well, the card I received back from you was:
-Same conditions as when I sent it, same amount of dust on the fan (although you used compressor to clean it)
-The fan still spins fine, just like it had done for the last 2 years. Temperatures of 60C idle are in my opinion very acceptable for a 8800GTX.
I dont doubt your 25+ years in this business, but I think we can both assume that had the fan motor really burned, when I plugged the card back in my PC, I would have smelled it right?
-The card works in 2d only, I can surf the net with it, look at my desktop, nothing more, but the temps are still the same, and the fan spins still, so, I dont think heat has anything to do with it.
I feel however very offended by your judgment about the amount of dust in my PC´s environment, it sounds really bad, I wish I could make you change your mind by showing you a picture of my case, that by the way, has good great airflow, its a full tower case with plenty of room, sitting on a wooden floor, and a large window on the side of the case with lights, all looking nice and tidy.
If thats not enough for your standards then I would be very interested in knowing what more is expected by ordinary Joe!
Best regards
Sent: Tuesday, April 21, 2009 10:24 AM
To: 'F. Sgar'
Subject: AW: AW: Refused RMA due to dust ( Europe) S/N: 60883143039xx
In an attempt to get the fan bach to move, yes.
The amount of dust in the card was the ultimate cause of the board dying on you.
You need to make sure that you are operating a computer in a suatable environment, and check every once a while that the inside of your case is clean.
The way PC cases are designed, and due to the fans that blow warm airt out of the case, the case as such behaves very similar to a vacuum cleaner. Dust has the tendecy to stick to warm objects and those that may have a static electric charge - usually high voltage components such as those found in your PSU.
There are dust guards available which you can place in front of the vent holes on your PC - they help solve the problem.
Again, we are not asking to take apart a graphics card for cleaning, but we are asking not to neglect it and ensure a reasonably clean operating environment. Dust, aside from water is about the worst enemy of electronics.
Please read our Warranty terms, section 3.3, which says something about NEGLECT. I#ve highlighted that for you:
Peter Tersluisen
Technical Director European Operations
[email protected]]
Gesendet: Dienstag, 21. April 2009 18:39
Cc: Kyle Sabine
Betreff: Re: AW: AW: Refused RMA due to dust ( Europe) S/N: 60883143039xx
Dear Sir
I appreciate you pointing me your section 3.3 of the Warranty once again, and also, to remind me what dust can do to electronic components and how to prevent this from happening.
However, you seem to be proving my point when you say that a customer it´s not expected to take apart a graphic card for cleaning, but then blaming it on the operating environment.
In other words you are blaming me for not keeping my PC clean, and that is for me an unacceptable excuse, and a very RUDE one, making it sound like I have cockroaches in my PC!!!
I still have strong believes that the card was never tested, was simply refused once the dust on the fan was spotted by one of you.
I had a close look at it today, I did not see any signs of the cooler being taking off, although you have mentioned to me that the dust was taken off it with a compressor, that is how you realized the fan motor was burned, but I have already told you that the fan was working when I sent you the card (and its still working now) and the dust was still there when i received the card back. Not to mention the temperatures of the card that have always be good (and still are), in contrary to your overheating statement.
I have been without the use of my main PC for more than 3 weeks, but I was forced at the end to buy another card, an XFX gtx260 to be more exact.
This whole issue has costed me quite some money, but you lost at least one customer (but don´t forget many have read this story on forums).
Best regards
Sent: Wednesday, April 22
Dear Sir,
Sorry if you feel offended by my pointing out the facts.
At the time we had the board in our hands and tested the board, the fan showed no movment. I have no plausible explaination why it would all of the sudden move now.
As stated in my earlier mails: We have never in 3 years of EVGA here in Europe seen cards with dust in that magnitude.
Just one question: If you have a car, I asume you do, don't you take it to service every once a while? What do you think would happen if your car's engine broke - would you get a warranty if you never made an oil change in 2 years? I don't think so!
Did you know that dust not only does damage to mechanical parts, but can contuct electric current? Did you know that you can invoke a dust explosion by a single spark?
So, that´s it, his word against mine.... I went and got myself a xfx gtx260 at the end. I dont know if its even worth keeping email him anymore, his answer is still the same.... dunno I might try to get hold of a digital camcorder and take a clip of the card with the fan working lol.
Thanks again for reading guys. I am well open to suggestions if you have any!!
