- 1 Dec 2005
hi guys,
Would like your help once again! Basically, this is for a HTPC which will probably be used occasionally for some light gaming. I do realise that the low powered 5050e would be ideal for me, but recently i've read a review which compares these two cpus. It turns out that the performance gap is larger than i had expected and the 7750BE did not really expend THAT much more power than the 5050e.
This machine will obviously be used primarily for HD decoding, which shouldn't be a problem for either cpus since i should be able to get the gpu to do most of the work through mpc or software like powerdvd.
So, would appreciate your inputs.
Thanks in advance,
RK
Thanks in advance,
RK
