Limited or no connectivity?
Caporegime
25 Nov 2004
On the road....
My LAN connection on my pc refuses to connect to the web reporting Limited or no connectivity, yet my wireless works fine.
My other 3 PC's all connect via my LAN just fine yet my own pc won't (previously it did with no issue!)
I decided to re-install windows and the problem persists!
Problem with my motherboard perhaps? - ASRock 4CoreDual SATA2
I have updated the motherboard & LAN drivers btw.
Any suggestions appreciated!
OS is XP Home, SP3.
Check the cable? Try different port on router/switch as well. Oh and on the network card properties, make sure the speed is set to Auto.
Had a similar problem recently, just seemed to be 1 pc that wouldn't work on the router, reinstalled OS, tried different cables, different ports on the router, even a different NIC, was working before as well for a good while. This wasn't my own personal problem btw. It was strangley enough fixed by firstly connecting the non-working pc to a hub and then from hub via uplink to the router and it worked!
Possibly something in the motherboard was playing up, but seemed a bit of a mystery, maybe you have the same thing.
I have tried most of the suggestions you mention mate, and will try the others later.
FWIW, I'm pretty convinced my Asroch board's a bit duff - I'm forever getting sound issues with it (regardless of on-board or my soundblaster card) and its forever losing my GFX drivers.
Moral of the story is don't buy a jack of all trades - master of none motherboard! :o:D
I'll report back if I have any joy. :)
Cheers.
One thing ive heard before is to press the power and reset buttons at the same time then ( let go ) and put switch the psu back on. Asus used to have this as a fall back to reset the network adaptors ( asrock being a sub brand of asus )
As a last resort I thought what the hell and decided to try this, I was not expecting it to do any good!
I was not sure if I was supposed to shut down first so just hit my power & reset button at the same time and unplugged my USB wireless adapter.
What do you know? it works! - I am posting this via my LAN / Ethernet. :)
I'll remember that one for future reference!
Thank You esK` :cool::cool::cool:
