Mk4 Golf
27 Mar 2004
England
I've come to terms with the fact that maybe a diesel is the way forward. I've spent £210 so far this month on petrol and I think a diesel would be suited to my commute.
I've been looking at MK4 Golf GT TDi's.
Which engine is the best? There seem to be a hell of a lot of 110's around.
I'm after a 130 or 150 really and i'm looking to remap.
Are there any issues with these? Do they handle well?
Most in my budget have about 80,000 miles + , do they run for ever or is this just a myth?
Any other derv suggestions for £4k are welcome.
Cheers.
You make one of these threads every other week - will you ever actually change your car?!
Yes it's what i'm intending on doing now, just when I sit down and do the maths i'm horrified with how much I spend on fuel.
I've done 6,000 in 3 months. Too much for a Clio imo.
Depends on your commute, my friends gets closer to 50 and his has 182k on the clock.
And im sure the 2 grand in your pocket will offset that ~5mpg less.
It needs to be reasonably quick though. My mates HDi was slower than my old Saxo VTR never mind the VTS.
Remapped Golf 130's can go upto 170bhp.
Why do you need it to be so fast for a commuting car?
Is it full of tiny roads with short straights that you absolutly have to nail it past 1 car and pull in then wonder why you get crap mpg?
A remapped HDI should be similar speed to a VTR, your mates just sounds shagged.
Need 50+ mpg really.
My mates only gets 42mpg :(
Want something Golf,Leon size.
Just to throw some figures in here, comparing 50MPG VS 42MPG, at 102.8p/litre for diesel, over 10k miles the cost at 42MPG would be £1,112.69 and at 5MPG it would be £934.66 - you would save £178.03. If there was a £2k price difference then it'd take approximately 112k miles to break even thanks to the saving on fuel.
I made a thread about it a while ago with an excel spreadsheet to calculate fuel costs, but spending more on a car because it has a slightly better MPG figure is often not worth it unless you're planning on keeping it for a very long time.
It's minor roads, sitting at 50-60mph, twisty and hilly.
It's not only a commuting car. It needs to be pretty nippy because seems times I fancy a little hoon.
I've worked out I would save the equivalent of around 50-60 litres of fuel a month using a derv.
130 is the engine of choice, but you'd be looking at a late 2002 car onwards which could be tough for £4k given that my Mum's 2000 1.6SE made £2800 on private sale the other week..
The TDIs came in a variety of power outputs. The is an 110 launch engine and isn't PD so they're a bit unrefined. PD (unit injector - VAG's answer to common rail) engines arrived in 2001 as a 115 which was replaced by the 130 in late 2002. 150 arrived later only as a proper spec GTI rather than the Highline (GT TDI in UK) of the 110/115/130. Some old 110s appeared after the PD engines launched as VW couldn't supply enough.
Handling can best be described as soft unless it's got the optional sports suspension. Steering is a bit numb. As far as I'm aware they're pretty reliable, some reports of injector wear at 120k+ on 110s.
50mpg is achievable depending on your driving. You'll never that around town, but it's capable of that on flowing A-road and the Motorway.
