Xbox 360 Elite RROD.
20 Nov 2006
Well my cousin has a 360 elite and has given it to me because is under the impression that it cant be fixed. Now im fairly sure it can be, could someone give me some tips or ideas as to how it can be sorted ?
Thanks.
RROD is covered by a 3yr warranty by Microsoft. I was under the impression that elites weren't yet 3 years old so you should be able to just send it off to MS and they'll fix it for free.
Well ive just tried to register the xbox to check the warranty but it looks like my cousin has already done this. How would i go about changing it into my name, so i can get the console sent back and repaired ?
Thanks.
Put it in the oven overnight.
Wouldn't do that, caps are only rated at 100c
Just do xclamp replacement and heat the GPU and CPU to "reball" the solder joints.
whole process takes about 30-45 misn and you can be playing the same day, fixed 3 for myself so far and not one of them has gone wrong since.
