I'm going to have the fun(?) task of wiring up my 7.1 speakers in a couple of months... I'm lucky (I think!) because I have plasterboard walls, so i've got the option to route all the wiring neatly 'inside' the walls and bring them to a central plate on the wall... i've just got a few questions.
Would I be right in thinking that electricians usually use fish tape to do this kinda thing? I've never done it before and i'm assuming there has to be a really easy simple solution to do it
I've done some googling and found 2 fish tape / cable access kits i'm considering (hoping it's okay to post these links, seeing as they're not competitors)
This one from Screwfix
Or
This one from VDC Trading (site seems to be down atm, but I think that was the right link, if not, just search for fish tape on the main site)
Last question - I understand that there will be various beams and studs(?) behind the wall, but are there usually horizontal beams that cover the entire depth of the wall? (therefore, totally blocking the cable) ?
Thanks for any info/tips!
Or
