cheers for the info!
tripods seem expensive!
Got a gorilla pod coming (not a proper tripod i know, but it isnt a replacement, just a useful accessory)
After years of experimenting, upgrading, researching, trial and error I have concluded that almost ever tripod and head in existence is rubbish, a good tripod and head is a necessary, and there is really only one ultimate option.
Really Right stuff BH-40 or BH-55 with a Gitzo Carbon 6x tripod (the standard mountaineer version, 3 piece leg).
This is around 800 GBP worth of support equipment. I have borrowed something similar to this (slightly different gitzo tripod, arca swiss ball head), and it is amazing how much better things become. I nearly went out that same day to lay down 800 smackers to get the gear there and then. But then I realized you needed special plates dedicated to the camera body, I will be upgrading my camera soon so will wait before ordering.
I went from 30GBP high street shop travel tripod, 90GBP no-brand heavy and big looking thing, to 2nd hand branded tripod at 120GBP (was something like 180 new). I don't want to make this a continual series of upgrades.
Now I could do yet another upgrade and buy a 300-400 GBP setup which I would be happy with for a while, but eventually would want to upgrade to the ultimate setup anyway. Thereby I loose 300GBP again!
My suggestion is, start off with a small bean-bag or buy a small gorrila pod just so the camera sits just off the ground and will be stable enough with your small lenses.
Save up about 3-4X what you think a tripod is worth and buy the best you can spending a couple of hundred. MAke sure you get a ball head. This should last you until you get heavier lenses like a 70-200 2.8 or 300 f/4. Once this happens Go straight for the Really Right Stuff BH-55 and top of the line Gitzo tripod. Pay the money, and don't look back.
I ruined years of photography with shoddy tripods that could even support a light Sigma 70-300mm properly. Let alone the fact for each photo I would spend 30-120 seconds each time fighting the tripod.
