Hi
Im after a new case that looks pretty good and has large internal fans and is pretty quiet with good airflow, aswell as looking good. It also needs to have the room for my water cooling setup, just one loop with cpu and gpu attached. I was thinking this
http://www.overclockers.co.uk/showproduct.php?prodid=CA-117-LL&groupid=701&catid=7&subcat=
Does anyone have this case and have any reviews on it. Also behind the front 3 fans , is there room for a 240mm radiator to be attached.
If not this then is there any others you would recomend, i would prefer a large outake fan on top if possible to get rid of the heat.
