Lian-Li pc-a06 case mods
17 Apr 2009
I thought I would start up a thread for all people with the `space saver` lian-li pc-a06. I have watercooled an nvidia 9800gx2 and a intel q6600 quad core with a xspc 450 watercooling kit fan blowing in and as an add-on an black ice gtx 160 radiator as the rear exhaust is 2 x 80mm. The two fans on the outside of the case are 80mm blowing in as is the front exhaust. There is a 120mm blowhole blowing out at the top rear to clear any latent heat issues.
Q6600 OC to 3.20ghz
Gigabyte GA-X38-DS5
9800gx2 stock speed
LG bluray burner
card reader
geil black dragon 4gb 5.5.5.15
Gigabyte 550w odin gt power supply
asus xonar dx card (onboard disabled)
XSPC 450 watercooling kit
Black ice gtx xtreme 160 radiator
sunbeam blue led case feet, standard generic grills for 120mm blowhole, bottom radiator. I think the feet allow more air to circulate the bottom radiator and add a nice effect, temperatures have dropped.
realtemp 3.0
q6600
idle
31 core 0
30 core 1
30 core 2
28 core 3
load
45 core 0
43 core 1
42 core 2
42 core 3
Techpowerup gpu-z 0.3.4
9800gx2
load
44
43
I can see why modders would prefer the PC-a05 because of the 120mm fan at the rear, this case is not as wide, more compact, essentially very similar in most ways.
just got to get some uv lighting, blue led fan for the blowhole and a side panel laser cut to finish it off.
Update just upgraded to a Black ICE GT Xtreme M160 Double Radiator from www.thecoolingshop.com this is the newer generation of radiators from Hardware Labs, boasts lots of improvements so I`m up for that.
I think I will go for another xilence blue led fan on the bottom radiator.
Am I the only one modding this case?
i'll be doing a watercooled build in one of these cases so we'll see how that goes. should be starting the log in a week or 2.
StevenG
I know this is an old topic , sorry for brining back to attention.
but is there anywhere that sells this case with the side window? ive looked everywhere and no luck ::(
