Looks pretty tidy Gareth and some good commitment there. Seems the car is setup very well with some progression in the grip limits, some parts you have some very nice throttle control which balances the car well through the corner and thats reflected in your corner exit speeds. Where you find the limit you did a good job and getting the car back together and carring on regardless even over the grass
My criticisms would be:
- Dont bother with heel and toeing yet. Its distracting your driving IMO, you are missing the turning points and dont seem to be as hard on the brakes as you can be in a skip, worry about H&T later one.
- A few times you are changing between throttle on and off with no real modulation but still keeping a pretty tight line, that suggest you should be able to enter corners faster but thats a pretty obvious thing to say whilst your relatively fresh to tracking any car let alone an S2000.
- Try to ignore the fact you are catching cars, particularly the fast status cars, you can see how you lose your composure when you catch the 911.
- Early Apexing is meaning you are getting on the power pretty late out of the corner theres a couple of corners behind the 911 where you can see him apex later and has a much straight drive out of the corner. Key to exiting is to get on the power only when you know you wont have to back again to tighten your line.
Main thing is you had fun though and learnt a lot about your car
Hope I dont end up sounding like a knobber know it all in that, i dont intend to, but then afterall Im not a 'real' petrolhead anymore anyway
