Titan Vulcan Overclock.
  • Thread starter Thread starter unknownsoldier64
  • Start date Start date
unknownsoldier64
unknownsoldier64
Had issues with my Titanvulcan removed the Overclock and it works Fine
went through some Settings with the support Tech and still getting the issue when the overclock is on
He has advised i flash the BIOS and Try again .....
Do you think this will work ?
Cheers
Are you confident you can flash it, if not then send it back and get them to fix the overclock settings or flash the BIOS for you :)
What were the problems you were experiencing?
System Crashes after 5 miniuts and randomly reboots while the overclock is on in the bios ..then without the overclock on the system runns fine ....
did you reslove your problem? I have a similar problem with this model. It keeps crashing and memory dumping at least 3 x a day which is becoming annoying! I'm going to call overclockers tomorrow and hopefully get it sorted
