- 18 Oct 2002
- Isle of Wight
After trying for months to get Klingon Academy to work under XP, Vista and Windows 7 using a range of different hardware and drivers... I gave up.
Last night I was rather bored and decided to build a new PC, using older components, Windows 98SE and legacy drivers. The spec:
Asrock 775i65G Mobo
2.53Ghz CPU
256 RAM (Generic PC2100)
Radeon 9600SE (AGP)
Surprisingly, I found Win98 drivers for the chipset (VIA 4in1), onboard LAN and sound. I grabbed the newest Win98 Radeon 9600 series drivers I could find. I also installed DirectX7, which is the version KA shipped with.
To be honest, I never expected to finish the build as I assumed there would be compatibility issues, resource conflicts etc. To my surprise, everything installed just fine with no issues. I ended up playing KA with various mods until 2am!!! Not a single crash or graphical glitch.
Sure, it’s not regarded as the best combat simulator out there. In fact, I’m sure many of you have no desire to play it again. But I thought I would post this information to help those who may be trying to get this game to work. I know it’s not an ideal solution, building a second PC to play just one game... but if you come across any other games that don’t work correctly within VM or modern O/S environments, at least there is another solution!
Best of luck!
Asrock 775i65G Mobo
2.53Ghz CPU
Radeon 9600SE (AGP)
Best of luck!
