Tsunami Dream too small! what next?
5 Dec 2005
Stockport
Hi, i have the Tsunami dream but i have got 4 HDD's and 2 Graphics cards in SLI, well i cant get SLI as i have no room! So i am asking what case should i get so i do have room for all this?
Also what kind of powersupply should i be looking for to power all this, thx in advance
I had this case.. Useless!
Anyway, what is your budget?
The Antec 300 is a decent case for around £50.
Personally, Ii love my Comos "S"
The PSU depends on all your components but generally, a 600w is a safe bet for the majority of higher end systems. A little more if you are running Crossfire/SLi setup.
Thx Huddy, i am willing to spend between £150 to £170 ish on case and powersupply, yeah Tsunami loooks good but damn its tight inside! i will take a look thx mate.
Just out of curiosity what make powersupply should i really avoid / be looking for?
As already said the Antec 300 is a great little case - some pics here - and as far as PSU goes most here recommend: Corsair, Coolermaster, BeQuiet! - if you can afford a modular one then so much the better especially for a midi sized case for avoiding unnecessary cable clutter!
The only thing that worries me about the 300 is that i have SLI 9600GT's and 4 HDD's going in it and i am not sure they will all fit, what do you think?
Having fitted a few Antec 300s and one with SLi, they are spacious enough for what you need - no problems. Make sure you get a few extra 12cm fans for the front intake. However, you may want a bigger case just for some comfort if you are thinking of future upgrades etc.
The P183 is a decent case: http://www.overclockers.co.uk/showproduct.php?prodid=CA-114-AN
