24 Apr 2009 at 14:39 #1 ssmacc ssmacc Soldato Joined 5 Mar 2007 Posts 2,880 Location Macclesfield Windows 7077 64bit PowerDVD 8 works fine but the HD-DVD work around does not, anyone successfully played HD –DVDs? I don't think PowerDVD 7 installs and 9 does not play HD-DVDs? Cheers
24 Apr 2009 at 14:53 #2 bledd bledd Don Joined 21 Oct 2002 Posts 46,892 Location Parts Unknown maybe install anydvdhd too
24 Apr 2009 at 14:59 #3 ssmacc ssmacc Soldato OP Joined 5 Mar 2007 Posts 2,880 Location Macclesfield Only just seen that the RC is 'out', might give that a try...
25 Apr 2009 at 17:53 #4 ultim ultim Associate Joined 6 Jan 2006 Posts 1,025 Location Midlands im using TotalMedia Theatre 3 to play HD DVDs, could try that.
25 Apr 2009 at 18:15 #5 deuse deuse Soldato Joined 17 Jul 2007 Posts 24,550 Location Solihull-Florida ultim said: im using TotalMedia Theatre 3 to play HD DVDs, could try that. Click to expand... Is that the version that uses Nvidia GPU?
25 Apr 2009 at 21:25 #6 ultim ultim Associate Joined 6 Jan 2006 Posts 1,025 Location Midlands deuse said: Is that the version that uses Nvidia GPU? Click to expand... yes
25 Apr 2009 at 22:35 #7 deuse deuse Soldato Joined 17 Jul 2007 Posts 24,550 Location Solihull-Florida ultim said: yes Click to expand... Thanks dude
26 Apr 2009 at 00:23 #8 MadMatty MadMatty Associate Joined 14 Jan 2005 Posts 1,571 Location Lincoln, UK PowerDVD 7 works, at least with the 7000 beta of windows 7
