Can someone with a Titan Goliath help me!
Permabanned
20 Dec 2008
Hello,
My Titan Goliath wasnt overclocked correcly when i recieved my system, so its running at the default 2.6 instead of the 3.4, Could someone who has this system check to see if there Motherboard Bios is the same as this one for 3.4Ghz.
Picture 1.
This is what i get as soon as i enter MB Intelligent Tweaker(M.I.T) in the bios..
Picture 2.
As you can see it shows it was set up to be clocked at 3.4, the settings looked like it was changed for that.
PC Health Status..
Once i click save the settings in the bios then exit then it reboots my system doesnt start up correctly. i have to manually keep restarting the PC until it boots up
Thanks in Advance
You might need to adjust the memory multplier / ratio, as screen 2 shows it is running at 1360mhz.
OCUk have a customer service thread here I'm sure if you post for some advice one of the team will get you running at 3.4ghz in no time at all.:)
TC
Have posted there but not getting problem resolved as quick as i wanted to, not OC's fault just wanted to know if anyone else could help me out quickly. Just wondering if anyone who has the same system could just check and match, just too see what the problem is.
I will contact Yewen and see if he can help.
Hi Jamesdavid3,
One of our technicians was going to call you to go through a few things after 5:30, did he manage to get through to you ok?
