Is My PC Clean??
I know its abit drastic but i always format my c drive as i always find that once a virus or trojan get in your system it very hard to get rid of unless its a small low threat virus the av software can kill easy. No offence but you are playing with fire running a av software that expired a year ago as new viruses come out everyday and your software will ignore them. You can buy Kaspersky Internet Security 2009 (thats firewall & antivirus) from overclockers for £14.94 whith 1 year subscription.
http://www.overclockers.co.uk/showproduct.php?prodid=SW-005-KA&groupid=33&catid=164&subcat=
Try cleaning up:
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Int ernet Settings,ProxyOverride = *.local
O15 - Trusted Zone: *.gomyhit.com (HKLM)
O20 - AppInit_DLLs: ,
(just check them then click fix or clean, I can't remember what HJT calls it)
Try cleaning up:
Thanks. That seems to have sorted out the browser problems. I'm going to run all my spyware programs again and then definitely buy some new AV.
Just backup your files and wipe the PC.
It'll save you time in the end. If you don't do it, you'll just keep fretting about whether you managed to clean the PC properly.
.. and hopefully not repeat the same practices that led to this infection.
I'm very reluctant to reformat my PC due to the time and hassle it would take. Here's my new HJT log. Does it look ok?
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 14:14:23, on 28/04/2009
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16827)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
C:\Program Files\Bonjour\mDNSResponder.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\WINDOWS\system32\PnkBstrA.exe
C:\WINDOWS\system32\PnkBstrB.exe
C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
C:\PROGRA~1\AVG\AVG8\avgrsx.exe
C:\PROGRA~1\AVG\AVG8\avgnsx.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Analog Devices\Core\smax4pnp.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\WINDOWS\system32\RUNDLL32.EXE
C:\Program Files\Lavasoft\Ad-Aware\AAWTray.exe
C:\PROGRA~1\AVG\AVG8\avgtray.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
C:\Program Files\NETGEAR\WG111v2 Configuration Utility\RtlWake.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\Program Files\Windows Media Player\wmplayer.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://news.bbc.co.uk/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll
O2 - BHO: Google Dictionary Compression sdch - {C84D72FE-E17D-4195-BB24-76C02E2E7C4E} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\Core\smax4pnp.exe
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [UserFaultCheck] %systemroot%\system32\dumprep 0 -u
O4 - HKLM\..\Run: [Ad-Watch] C:\Program Files\Lavasoft\Ad-Aware\AAWTray.exe
O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'Default user')
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O4 - Global Startup: WG111v2 Smart Wizard Wireless Setting.lnk = ?
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O9 - Extra button: PokerStars - {3AD14F0C-ED16-4e43-B6D8-661B03F6A1EF} - C:\Program Files\PokerStars\PokerStarsUpdate.exe
O9 - Extra button: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Program Files\PartyGaming\PartyPoker\RunApp.exe
O9 - Extra 'Tools' menuitem: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Program Files\PartyGaming\PartyPoker\RunApp.exe
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {56762DEC-6B0D-4AB4-A8AD-989993B5D08B} (OnlineScanner Control) - http://www.eset.eu/buxus/docs/OnlineScanner.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://www.update.microsoft.com/mic...ls/en/x86/client/wuweb_site.cab?1203166996546
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://www.update.microsoft.com/mic...ls/en/x86/client/muweb_site.cab?1203166986171
O16 - DPF: {D8089245-3211-40F6-819B-9E5E92CD61A2} (FlashXControl Object) - https://flashpoker.ladbrokes.com/ladbrokes/FlashAX.cab
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O18 - Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
O20 - Winlogon Notify: avgrsstarter - C:\WINDOWS\SYSTEM32\avgrsstx.dll
O23 - Service: Apple Mobile Device - Apple, Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: AVG Free8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Lavasoft Ad-Aware Service - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: PnkBstrA - Unknown owner - C:\WINDOWS\system32\PnkBstrA.exe
O23 - Service: PnkBstrB - Unknown owner - C:\WINDOWS\system32\PnkBstrB.exe
O23 - Service: StarWind iSCSI Service (StarWindService) - Rocket Division Software - C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
End of file - 8084 bytes
Here's my ComFix log too.
ComboFix 09-04-25.A3 - James 28/04/2009 15:23.1 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.3327.2597 [GMT 1:00]
Running from: c:\documents and settings\James\Desktop\ComboFix.exe
AV: AVG Anti-Virus Free *On-access scanning disabled* (Updated)
* Created a new restore point
((((((((((((((((((((((((( Files Created from 2009-05-28 to 2009-4-28 )))))))))))))))))))))))))))))))
2009-04-27 14:24 . 2009-04-27 23:29 -------- d--h--w C:\$AVG8.VAULT$
2009-04-27 13:57 . 2009-04-27 13:57 10520 ----a-w c:\windows\system32\avgrsstx.dll
2009-04-27 13:57 . 2009-04-27 13:57 108552 ----a-w c:\windows\system32\drivers\avgtdix.sys
2009-04-27 13:57 . 2009-04-27 13:57 325640 ----a-w c:\windows\system32\drivers\avgldx86.sys
2009-04-27 13:57 . 2009-04-28 13:24 -------- d-----w c:\windows\system32\drivers\Avg
2009-04-27 13:56 . 2009-04-27 13:56 -------- d-----w c:\program files\AVG
2009-04-27 13:56 . 2009-04-27 13:56 -------- d-----w c:\documents and settings\All Users\Application Data\avg8
2009-04-27 00:25 . 2009-04-27 22:38 99477 ----a-w C:\MGlogs.zip
2009-04-27 00:25 . 2009-04-27 22:38 -------- d-----w C:\MGtools
2009-04-26 13:27 . 2009-04-26 13:27 -------- d-----w c:\documents and settings\All Users\Application Data\SUPERAntiSpyware.com
2009-04-26 13:27 . 2009-04-26 13:27 -------- d-----w c:\program files\SUPERAntiSpyware
2009-04-26 13:27 . 2009-04-26 13:27 -------- d-----w c:\documents and settings\James\Application Data\SUPERAntiSpyware.com
2009-04-26 13:27 . 2009-04-26 13:27 -------- d-----w c:\program files\Common Files\Wise Installation Wizard
2009-04-26 13:24 . 2009-04-26 13:24 1340797 ----a-w C:\MGtools.exe
2009-04-26 13:18 . 2009-04-26 13:18 -------- d-----w c:\program files\CCleaner
2009-04-26 11:57 . 2009-04-26 12:42 -------- d-----w c:\program files\EsetOnlineScanner
2009-04-25 22:23 . 2009-04-25 22:23 -------- d-----w c:\program files\Trend Micro
2009-04-25 22:23 . 2009-04-25 22:23 -------- d-----w c:\documents and settings\James\Application Data\Malwarebytes
2009-04-25 22:23 . 2009-04-06 14:32 15504 ----a-w c:\windows\system32\drivers\mbam.sys
2009-04-25 22:23 . 2009-04-06 14:32 38496 ----a-w c:\windows\system32\drivers\mbamswissarmy.sys
2009-04-25 22:23 . 2009-04-25 22:54 -------- d-----w c:\program files\Malwarebytes' Anti-Malware
2009-04-25 22:23 . 2009-04-25 22:23 -------- d-----w c:\documents and settings\All Users\Application Data\Malwarebytes
2009-04-25 22:04 . 2009-04-25 22:04 -------- d-----w C:\VundoFix Backups
2009-04-25 11:32 . 2009-04-25 11:32 -------- d-----w c:\documents and settings\James\Local Settings\Application Data\ESET
2009-04-21 01:39 . 2009-04-21 01:39 -------- d-----w c:\program files\Audacity
2009-04-16 15:09 . 2009-03-27 06:58 1203922 -c----w c:\windows\system32\dllcache\sysmain.sdb
2009-04-16 15:09 . 2008-05-03 11:55 2560 ------w c:\windows\system32\xpsp4res.dll
2009-04-16 15:09 . 2008-04-21 12:08 215552 -c----w c:\windows\system32\dllcache\wordpad.exe
2009-04-16 15:09 . 2009-03-06 14:22 284160 -c----w c:\windows\system32\dllcache\pdh.dll
2009-04-16 15:09 . 2009-02-09 12:10 729088 -c----w c:\windows\system32\dllcache\lsasrv.dll
2009-04-16 15:09 . 2009-02-09 12:10 473600 -c----w c:\windows\system32\dllcache\fastprox.dll
2009-04-16 15:09 . 2009-02-09 12:10 453120 -c----w c:\windows\system32\dllcache\wmiprvsd.dll
2009-04-16 15:09 . 2009-02-09 12:10 401408 -c----w c:\windows\system32\dllcache\rpcss.dll
2009-04-16 15:09 . 2009-02-06 11:11 110592 -c----w c:\windows\system32\dllcache\services.exe
2009-04-16 15:09 . 2009-02-06 10:10 227840 -c----w c:\windows\system32\dllcache\wmiprvse.exe
2009-04-16 15:09 . 2009-02-09 12:10 714752 -c----w c:\windows\system32\dllcache\ntdll.dll
2009-04-16 15:09 . 2009-02-09 12:10 617472 -c----w c:\windows\system32\dllcache\advapi32.dll
2009-04-14 01:04 . 2009-04-14 01:04 -------- d-----w c:\windows\system32\KB905474
2009-04-14 01:04 . 2009-03-10 21:26 1403264 ----a-w c:\windows\system32\KB905474\wganotifypackageinner.exe
2009-04-14 01:04 . 2009-03-10 21:18 453512 ----a-w c:\windows\system32\KB905474\wgasetup.exe
2009-04-14 01:04 . 2009-02-09 17:51 12490 ----a-w c:\windows\system32\KB905474\wga_eula.txt
2009-04-08 00:52 . 2009-04-24 13:16 -------- d-----w c:\documents and settings\James\Local Settings\Application Data\FullTiltPoker
2009-04-08 00:50 . 2009-04-24 13:23 -------- d-----w c:\program files\Full Tilt Poker
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2009-04-28 12:19 . 2008-10-17 17:44 42347 ----a-w C:\aaw7boot.log
2009-04-27 23:20 . 2008-02-19 18:12 189072 ----a-w c:\windows\system32\PnkBstrB.exe
2009-04-27 22:49 . 2008-02-19 18:12 138920 ----a-w c:\windows\system32\drivers\PnkBstrK.sys
2009-04-27 22:46 . 2008-02-19 13:58 -------- d-----w c:\program files\EA GAMES
2009-04-27 22:46 . 2008-02-16 12:44 -------- d--h--w c:\program files\InstallShield Installation Information
2009-04-27 22:44 . 2008-02-23 00:39 -------- d-----w c:\program files\Ares
2009-04-27 22:23 . 2008-02-16 14:43 -------- d-----w c:\documents and settings\All Users\Application Data\Google Updater
2009-04-27 14:29 . 2008-10-17 16:30 -------- d-----w c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
2009-04-25 22:16 . 2009-04-25 22:04 159 ----a-w C:\VundoFix.txt
2009-04-25 22:14 . 2009-01-31 17:52 15688 ----a-w c:\windows\system32\lsdelete.exe
2009-04-25 22:14 . 2009-01-31 16:55 64160 ----a-w c:\windows\system32\drivers\Lbd.sys
2009-04-24 13:26 . 2008-08-05 11:44 -------- d-----w c:\program files\PokerStars
2009-04-05 12:27 . 2008-05-20 18:28 -------- d-----w c:\documents and settings\James\Application Data\dvdcss
2009-03-17 01:42 . 2008-10-17 12:14 -------- d---a-w c:\documents and settings\All Users\Application Data\TEMP
2009-03-12 16:35 . 2008-10-17 16:30 -------- d-----w c:\program files\Spybot - Search & Destroy
2009-03-06 14:22 . 2003-03-31 12:00 284160 ----a-w c:\windows\system32\pdh.dll
2009-03-06 01:33 . 2008-02-19 18:12 75064 ----a-w c:\windows\system32\PnkBstrA.exe
2009-03-03 00:18 . 2006-06-23 11:33 826368 ----a-w c:\windows\system32\wininet.dll
2009-02-20 18:09 . 2004-08-04 07:56 78336 ----a-w c:\windows\system32\ieencode.dll
2009-02-14 20:37 . 2009-02-14 20:39 737280 ----a-w c:\windows\iun6002.exe
2009-02-09 12:10 . 2003-03-31 12:00 729088 ----a-w c:\windows\system32\lsasrv.dll
2009-02-09 12:10 . 2005-07-26 04:31 401408 ----a-w c:\windows\system32\rpcss.dll
2009-02-09 12:10 . 2003-03-31 12:00 714752 ----a-w c:\windows\system32\ntdll.dll
2009-02-09 12:10 . 2003-03-31 12:00 617472 ----a-w c:\windows\system32\advapi32.dll
2009-02-09 11:13 . 2003-03-31 12:00 1846784 ----a-w c:\windows\system32\win32k.sys
2009-02-06 11:11 . 2003-03-31 12:00 110592 ----a-w c:\windows\system32\services.exe
2009-02-06 11:06 . 2003-03-31 12:00 2145280 ----a-w c:\windows\system32\ntoskrnl.exe
2009-02-06 10:39 . 2003-03-31 12:00 35328 ----a-w c:\windows\system32\sc.exe
2009-02-06 10:32 . 2002-08-29 01:04 2023936 ----a-w c:\windows\system32\ntkrnlpa.exe
2009-02-03 19:59 . 2003-03-31 12:00 56832 ----a-w c:\windows\system32\secur32.dll
2008-04-13 01:37 . 2008-02-16 17:06 17920 ----a-w c:\documents and settings\James\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2008-02-22 13:20 . 2008-02-22 13:20 22328 ----a-w c:\documents and settings\James\Application Data\PnkBstrK.sys
2008-08-24 22:40 . 2008-08-24 22:40 32768 --sha-w c:\windows\system32\config\systemprofile\Local Settings\History\History.IE5\MSHist012008082420080825\index.dat
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"CTFMON.EXE"="c:\windows\system32\ctfmon.exe" [2008-04-14 15360]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-02-16 68856]
"SpybotSD TeaTimer"="c:\program files\Spybot - Search & Destroy\TeaTimer.exe" [2009-03-05 2260480]
"SUPERAntiSpyware"="c:\program files\SUPERAntiSpyware\SUPERAntiSpyware.exe" [2009-03-23 1830128]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"UserFaultCheck"="c:\windows\system32\dumprep 0 -u" [X]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2008-05-02 13529088]
"SoundMAXPnP"="c:\program files\Analog Devices\Core\smax4pnp.exe" [2006-12-18 868352]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-01-11 39792]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2008-02-19 267048]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2008-05-02 86016]
"Ad-Watch"="c:\program files\Lavasoft\Ad-Aware\AAWTray.exe" [2009-04-25 516440]
"AVG8_TRAY"="c:\progra~1\AVG\AVG8\avgtray.exe" [2009-04-27 1932568]
"nwiz"="nwiz.exe" - c:\windows\system32\nwiz.exe [2008-05-02 1630208]
[HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run]
"CTFMON.EXE"="c:\windows\System32\CTFMON.EXE" [2008-04-14 15360]
c:\documents and settings\All Users\Start Menu\Programs\Startup\
Microsoft Office.lnk - c:\program files\Microsoft Office\Office10\OSA.EXE [2001-2-13 83360]
WG111v2 Smart Wizard Wireless Setting.lnk - c:\program files\NETGEAR\WG111v2 Configuration Utility\RtlWake.exe [2008-2-16 745472]
[hkey_local_machine\software\microsoft\windows\currentversion\explorer\ShellExecuteHooks]
"{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA}"= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 77824]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\!SASWinLogon]
2008-12-22 11:05 356352 ----a-w c:\program files\SUPERAntiSpyware\SASWINLO.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\avgrsstarter]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Lavasoft Ad-Aware Service]
@="Service"
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\AuthorizedApplications\List]
"%windir%\\system32\\sessmgr.exe"=
"c:\\WINDOWS\\system32\\PnkBstrA.exe"=
"c:\\WINDOWS\\system32\\PnkBstrB.exe"=
"c:\\Program Files\\Activision\\Call of Duty 4 - Modern Warfare\\iw3mp.exe"=
"c:\\Program Files\\SopCast\\SopCast.exe"=
"c:\\Program Files\\SopCast\\adv\\SopAdver.exe"=
"c:\\Program Files\\Bonjour\\mDNSResponder.exe"=
"c:\\Program Files\\iTunes\\iTunes.exe"=
"c:\\Program Files\\TVUPlayer\\TVUPlayer.exe"=
"%windir%\\Network Diagnostic\\xpnetdiag.exe"=
"c:\\Program Files\\Activision\\Call of Duty - World at War\\CoDWaWmp.exe"=
"c:\\Program Files\\Activision\\Call of Duty - World at War\\CoDWaW.exe"=
"c:\\Program Files\\iPod\\bin\\iPodService.exe"=
"c:\\Program Files\\AVG\\AVG8\\avgupd.exe"=
"c:\\Program Files\\AVG\\AVG8\\avgnsx.exe"=
R3 RTLWUSB;NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter NT Driver;c:\windows\system32\DRIVERS\wg111v2.sys [2005-04-21 112384]
S0 Lbd;Lbd;c:\windows\system32\DRIVERS\Lbd.sys [2009-04-25 64160]
S1 AvgLdx86;AVG Free AVI Loader Driver x86;c:\windows\System32\Drivers\avgldx86.sys [2009-04-27 325640]
S1 AvgTdiX;AVG Free8 Network Redirector;c:\windows\System32\Drivers\avgtdix.sys [2009-04-27 108552]
S1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\SASDIFSV.SYS [2009-03-23 9968]
S1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.sys [2009-03-23 72944]
S2 avg8wd;AVG Free8 WatchDog;c:\progra~1\AVG\AVG8\avgwdsvc.exe [2009-04-27 298264]
S2 EAPPkt;Realtek EAPPkt Protocol;c:\windows\system32\DRIVERS\EAPPkt.sys [2005-04-01 66048]
S2 Lavasoft Ad-Aware Service;Lavasoft Ad-Aware Service;c:\program files\Lavasoft\Ad-Aware\AAWService.exe [2009-04-25 953168]
S3 SASENUM;SASENUM;c:\program files\SUPERAntiSpyware\SASENUM.SYS [2009-03-23 7408]
Contents of the 'Scheduled Tasks' folder
2009-04-20 c:\windows\Tasks\Ad-Aware Update (Weekly).job
- c:\program files\Lavasoft\Ad-Aware\Ad-AwareAdmin.exe [2009-01-18 22:13]
2009-04-18 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 12:34]
2009-04-28 c:\windows\Tasks\Google Software Updater.job
- c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2008-02-16 11:20]
2009-04-28 c:\windows\Tasks\WGASetup.job
- c:\windows\system32\KB905474\wgasetup.exe [2009-04-14 21:18]
------- Supplementary Scan -------
uStart Page = hxxp://news.bbc.co.uk/
uSearchMigratedDefaultURL = hxxp://www.google.com/search?q={searchTerms}&sourceid=ie7&rls=com.microsoft:en-US&ie=utf8&oe=utf8
uSearchURL,(Default) = hxxp://www.google.com/search?q=%s
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\Office10\EXCEL.EXE/3000
Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - c:\program files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
catchme 0.3.1398 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2009-04-28 15:24
Windows 5.1.2600 Service Pack 3 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
scan completed successfully
hidden files: 0
--------------------- DLLs Loaded Under Running Processes ---------------------
- - - - - - - > 'winlogon.exe'(776)
- - - - - - - > 'explorer.exe'(3688)
c:\progra~1\WINDOW~2\wmpband.dll
c:\windows\system32\WPDShServiceObj.dll
c:\windows\system32\PortableDeviceTypes.dll
c:\windows\system32\PortableDeviceApi.dll
Completion time: 2009-04-28 15:25
ComboFix-quarantined-files.txt 2009-04-28 14:25
ComboFix2.txt 2009-04-27 00:39
ComboFix3.txt 2009-04-26 14:36
Pre-Run: 119,755,640,832 bytes free
Post-Run: 119,897,169,920 bytes free
193 --- E O F --- 2009-04-16 17:18
